Can i hook multiple amps to two subs
  • 2
Bass so loud it HZ
CarAudio.com Regular
Ok i just ordered to 18 inch subs i have two jp23s strapped and they need more power then that .i ordered 2 2ohmdvc subs .i prolly should have ordered the 1 ohm and ran it at half ohm but my question is i have 2 other jp23s could i wire 2 strapped to one sub and 2 strapped to the other sub .they are both going to be in the same box ..TIA
I would advise against that. In my experience, wiring strapped amplifiers below rated impedance is a bad idea for daily.
I would strap 2 of the amplifiers to the subs at 2 ohms and throw the other two on eBay or facebook marketplace. A Taramps MD8000 2 ohm is $469 on Amazon. Selling 2 of the JP23’s would get you close.
Ok ill just do the two ohm for now .i have really good electrical .ill prolly just go ahead and buy a bass 8 or 12 k for now until i can get a salt or crescensdo .ik alot of ppl running them at half ohm and if i blow it owell its cheap .appreciatte it
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
159
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
12
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
Bass so loud it HZ
Bass so loud it HZ
IN, United States
Bass so loud it HZ
