mustang wall port placement
  • 4
9515ROB
TEAM DTF
2,385
Sherman IL
ight well i have a 98 mustang with 1 9515 in there right now and i just bought another 1 and i plan on walling it the ? i got is where should i put the port where it is gonna have the best sound and #s
Drivers side
Pass side
Middle
and not the bottom
let me know what you think
i done port on drivers side with my 01 but the build was not very good.every thing was removeable in less then an hour so i didnt get good numbers.just making the 50 mark on
most say that port on driver's side is the loudest, but honestly you'd have to build multiple ways and test to really find out. My port is in the middle and does just fine...
We built a Mustand with 8 10"s and ran the port across the top. It was hitting 154 with 1 Banda 2nd on 12v @ 1 ohm nominal. We were in the process of putting more power when the Maryland state police ticketed the car and we had to rip out the build because it obstructed the rear view mirror. You might want to check your local laws before you build a wall in your stang so it isnt for not............
how many rms is that amp
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Might not even be an issue if you don't have any really big panels on it. Otherwise dowels or threaded rod across your wide panels would be the...
18
I ordered the car with the upgraded B&O audio system....turn's out Ford bought the name but they didn't buy the quality. The system ****** to me...
Contact ANS he has a used Focal 8 Channel DSP that went for 1,300 bucks and is selling used I think shipped for 450. And from what I have seen and...
13
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
9515ROB
TEAM DTF
9515ROB
Sherman IL
9515ROB
    May 18, 2024
    May 16, 2024
