My 2003 Civic Install
All my **** laying in a pile, this grew more as the day progressed
Just finished running power wire
Applied 1st coat of edead V3
Started building hidden floor for amps, 2 amps and h701 will be hidden, and the 2
nine.1 sub amps will be hanging from rear deck in trunk in mid air, a suspended amp rack i suppose. Still not sure about the plans for the 2 13av.2 subs, most likely sealed either in one box or 2 seperate boxes opposing each other, they will be too heavy to move in and out if mounted together, something like 60 pounds a piece, plus whatever the box ends up weighing, pics coming soon
I went with 0/1 guage Enetic Power and ground wires from Elemental Designs website, awsome stuff, something like 4,500 strands of wire, oxygen free, 2.25$ a foot, going to use the extra i purchased for my big 3 upgrade soon. We ran dayton 14 ga speaker wire for all the speakers, will probably use 10 or 12 ga for my subs when they come in, so far 100 feet spool has been used, ned another 40 feet to run 2 more front stage drivers
yea i got a suggestion.
need to do another filler to get rid of the pinholes and imperfections, fill the top edge where i glued the trim plate in. and paint it. so far it looks great, the H701 moulds in there quite nicely just gotta do a few more things to finish it up though. we also built a trunk tub to mount his amps in the tirewell, ill get pics of that in the next few days. and after that we need to reassemble the trunk liner and what not and make a false floor to hide it all. its comming along, slowly but shurely.
comments? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I like that too, especially since it's for my car. Once again god ole' req got out the dremmel tool and cut alot of fat off of my metra dash kit, reloacating this and that and moving some bars around. We just need to put another coat of bondo and a little more sanding, followed by some flat black spray paint, H701 will be here on wednesday, will wire the c701 tommorrow after work, and finish my trunk if all goes well
trimmed the inside of the door panel down to fit the larger diamater speakers.
thems the midbassuz
fabbed up a quick bracket for his c701
isnt that beautius?
lets hear what you have to say //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Might not even be an issue if you don't have any really big panels on it. Otherwise dowels or threaded rod across your wide panels would be the...
18
Please. Quit talking shitt. I might be dumb but I'm not stupid.🤣
16
Polk Audio DB Series with or without an amplifier. MM Series on an amplifier
706
Dtour
Addicted to sound
Dtour
Virginia Beach
James Bang
