My 2nd Install - What do you guys think?
  • 1
raider89
OH
Still need to do some finishing touches. Thanks to Shredder2 for the box design.
CAB 2000.1 pushing a American Bass HD12 D2 wired to 1 ohm. Runng 1/0 power and ground, Duralast Platinum AGM Battery. 4 gauge "Big 4 Upgrade".
Working on getting the 270amp alternator installed since im pretty sure its gonna clip if I crank it higher as the cone is getting warm to the touch, could also be these 100 deg days. Might looking into the SMD to set input/gain properly. Its in a 2015 lancer.
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
7
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
9
This works. Using a 550Watt RMS Amp. The sub is 600-1800 RMS. No Battery Draining BS. Still sounds clean and low. But DD Amp goes lower and hits...
22
raider89
raider89
OH
raider89
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
