SOLD My Fi X svc 4 ohm for your 8" sub
wilzyx
village idiot/racist
I have a brand new never seen power Fi X 12" svc 4 ohm sub. I won this in a contest a few years back when I guess the founder of Fi Audio's age (Scott I think it was, and if I remember correctly he was 34 at the time). I had him build it for me with only a single voice coil because my amp at the time could power it just fine at 4 ohms, and I believe it was the only one made with a single voice coil. It's been sitting in my closet ever since and I just have no use for it since I just can't fit a 12 in my single cab 93 Toyota pickup. I'm interested in maybe an E8 or an RE 8 as I'm more sq oriented but I'm open to anything just let me know what you got and let's see if we can make a deal.
Edit: Pics are kind of old and shitty but I can take more if you need them.
Specs for the dual 4
X series clearance - SSA Car Audio Forum
12 DUAL 4
Fs: 25.7 Hz
Re: 3.9 Ohms/coil
Qms: 4.01
Qes: .38
Qts: .35
Mms: 120g
Cms: 3.2mm/N
Sd: 480cm^2
Vas: 104.1 l
Spl: 88.6dB 1W/1m
Bl: 20.0 N/A
Xmax: 16mm
Rms: 300W
Sealed box: .9-1.3 cuft
Ported box: 1.6-2.2 cuft
Sub OD: 12.500
Cut ID: 11.125
Mounting depth: 5.750
Displacement: 0.10cuft
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
Before I started to cut wiring, I would just leave one of the connectors unplugged. Based on your 3rd image, it looks like the wiring was spliced...
I would not recommend it if all subs are sharing the same chamber. I myself wouldnt do it at all. I would recommend get or having a tuned...
869
wilzyx
wilzyx
Des Moines, Iowa
fasfocus00
maylar
    Jun 2, 2024
    Jun 1, 2024
