How to wire 4 svc 6.5 door speakers to a 4 channel amp
  • 5
Yes.. One speaker to each Channel for 4 ohms. You can also wire Two together for a 2 ohm load having 2 on two channels freeing up the other two channels to use for other speakers if youd like and other configurations. Get a manual and go by the information provided to properly wire that amp correctly towards stability
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
5
55
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
533
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
893
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
870
Ufc_fan918
CarAudio.com Newbie
Ufc_fan918
Tulsa
SilverSquared
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
