My New Moofer Amp
One popped off one of my Orion 2500d's, I just pulled off the panel and used one from the output side and put it on the input. When you pull it off it has two tabs, I bent one side down so it wouldn't come off again, only one side is connected so it's easy enough to do. I had no issues playing music after that.
hmmmm
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
319
6
455
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
743
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
542
infamous_e46
hArRy_DaNgLeRs
infamous_e46
California
infamous_e46
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
