My used Kicker SX900.2 for used but working Rockford Fosgate Power HX2 RFR3112.
  • 2
Chollis
Kicker SX900.2:
Condition: Used not abused and missing end caps, but functioning perfectly. It's a beast. I would really like to trade for a 12" Rockford Fosgate Power HX2 RFR3112 preferably, but I am looking for at least one bad *** 12. I'll post an actual picture of the amp when I get home from work. Make me an offer. Here's the specs:
Kicker SX900.2 2-Channel Amplifier with DSP
32-Bit User-Programmable Digital Signal Processing
RMS Power Rating:
213 watts x 2 channels @ 4 Ohms
425 watts x 2 channels @ 2 Ohms
850 watts x 1 channels @ 4 Ohms Bridged
UltraMatch Gain Structure, single-band parametric KickEQ (Variable Gain, Boost, and Q), and crossovers ( Variable High and Low-Pass Filters )
SAMS (Stereo And Mono Simultaneously)
ISIS (Indicate Status & Input Settings) Interface
BLAST Port (Bass Level And Signal Transfer) Provides Remote Bass Level Control and control signal transfer between multiple SX amplifiers
Kompressor
Adjustable Phase Control: 0 - 180°
EndKaps: Cast aluminum, custom, removable covers to protect and hide all your wiring connections to the amplifier
SickBay and On Board Diagnostics
Frequency Response: 20 Hz - 200 kHz
Variable Input Sensitivity: 1V / 2V / 4V / 8V / 16V
Signal-to-Noise Ratio: >100 dB
MOSFET Power Supply
RCA Outputs: 1 Pair
Remote Gain Control
Fan Cooling
Dimensions (With Endcaps): 25-3/4" L x 10" W x 2-1/2" H
Trade for 2 almost mint rockford fosgate Punch HX2 12's?Dual 4 ohms. rated at 500wrms but will take 1kwrms easily. these are the 3" VC ones.
Re you talking about the RFD2212? I definitely want something beefier than that. Even if I don't get the fosgate power HX2, I was looking for something more powerful and higher end in general.
I own one of the S.M.S.L SU-1 MQA MQA-CD DAC. I got it to play off my stable platter CD player, a Pioneer Elite PD-59 that I use as a transport to...
10
981
I was browsing parts express. It seemed like around $180 for a 300 watt plate amp. The dimensions are not identical, new amps seem larger by a few...
5
My 1964 fender vibroverb. It’s a tube amp for guitar. It has broken many times. But it is a serviceable amp. I can fix it.
73
13K
Chollis
Chollis
Los Angeles
Chollis
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
