Need 1 10" that can handle 1000 watts
Other way around, Icon for sure, not the Xcon. Icon10 is $275 at ssa store vs $369 for xcon 10
ICON-10 D2
Couldn't remember which way it went and was too lazy to look lulz
---------- Post added at 12:26 PM ---------- Previous post was at 12:25 PM ----------
SPL DVC 1ohm
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
SA-10, Skar 10, SSA Icon, Fi Q, Fi BL, IA Lethal Injection, IA Flatlyne, Ascendent Audio Chaos, Ascendent Audio Havoc (not sure of pricing).
I'm in the same boat as you, running a single 10 on 1200w. I went with the SA-10 from Sundown. Got it b-stock at like $140 shipped, phenomenal deal.
Used, B-Stock, Refurbished Amps, and MISC - SSA Car Audio Forum there's the link for info on what I got. they have three D2's left, exactly what you need to run at 1 or 4 ohms. If you need to run at 2 ohms, you're SOL there. But the rest of the suggestions should work. There's great used deals too.
Also, http://www.soundsolutionsaudio.com/forum/topic/52478-single-skar-vvx-101215-custom-ported-box-package-deal/
that's another insanely good deal. Because you do need a proper enclosure for your subwoofer. Those Skars are sick, clean, and loud. They WILL handle 1k rms daily. You aint gonna get any better deal there, wish it was around when I was looking for a sub.
That HDC would like more around 2k lol you won't get much out of it from just 1k
I get quite a bit out of my 18 and it has aluminum coils too, with just 1k, probably not even that cause my ****** stock electrical.
Just my input, I don't doubt you could be right on that.
SA-10, Skar 10, SSA Icon, Fi Q, Fi BL, IA Lethal Injection, IA Flatlyne, Ascendent Audio Chaos, Ascendent Audio Havoc (not sure of pricing).I'm in the same boat as you, running a single 10 on 1200w. I went with the SA-10 from Sundown. Got it b-stock at like $140 shipped, phenomenal deal.
Also, Single SKAR VVX-10/12/15 Custom Ported Box Package Deal - SSA Car Audio Forum
nice, thanks for the heads up on these
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
211
Thanks for your input! I did some research and wanted to share what I found for anyone else in a similar situation. It turns out that the Honda...
177
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
510
FrisbieT
FrisbieT
Elk Point, SD
Bass Addict
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
