Need a bad DB Drive PLT15WD D2
  • 1
manyhobbies
Does anyone have a bad DB Drive PLT15WD D2 sub laying around that I could use for measuring to get recones made? Seriously I would rather not have to rip 1 of mine apart unless 1 takes a complete dump. I rarely ask for help, but if someone can help please speak up. I really don't wanna have to buy 1 but may work with someone to have the ability to get the measurments I will need to send to PSI for the recones.
I will give or receive a number in a PM if you can help.
Thanks, Russ.
I also just checked the voltage and the voltage on the amp in 12.85 and the rest of my stuff like my lc2i and remote out wire is 12.10. could that...
6
55
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
178
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
133
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
475
manyhobbies
manyhobbies
Celina, Ohio
manyhobbies
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
