need a big amp
tjjohnson91
looking from one big amp or two AQ2200's somthing on that line
i have two mojo's i want to put 2.5k rms to them each they are D2 so i need a good 2ohm amp or .5ohm...... but also have a treo SSX 18 id like to put atleast 4k to....
maybe a Mmats 4000.05?
otherwise just let me know what you have!!!
I have a SOUNDSTREAM XXX10000 for 900 shipped
I got Kicker ZX2500.1 for 390 shipped/paypalled
positive that it is underrated.
Workhorse amp and very efficient.
You can find another one to make it 5k
195
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
147
505
tjjohnson91
tjjohnson91
welcome mn
JarvisB
audiobaun
    May 19, 2024
    May 19, 2024
