Need a good mids/highs amp
  • 4
While those drivers are rated to handle 300W, you don't need that much to get stupid loud in a car. These are professional sound reinforcement woofers made to fill a room.
I can get an 800w powerbass amp for $70 would that work i just dont wanna ruin the evs this is my first time running them.@
If you do not want to ruin them, do not put a $70 amplifier on them.
They are 8ohm.. I have options but they are like 3-6x that price.
you need a minimum of 2 channels so most mono cheap amps wont work
invest $150-200 and get a realistic amplifier (ppi900.4), invest double that for much better quality, reliability, and tuning capability
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
173
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
127
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
471
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
363
Mike88317
Mike88317
Providence, RI
wew lad
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
