Need A Little Help With Gluing Surround Back To Cone
  • 2
Well, this topic has probably been covered but I'm failing to find my exact answer. I have a Audiobahn AW1206Q 12" woofer that has a little separation between the foam surround and the cone. I'm 95% sure I can glue this. It's about a 4" separation.
My options for glue are no name superglue and Gorilla Glue. The Gorilla Glue seems promising, but I wanted a little help before I dove into it. I'm also curious how to effectively clamp the come to the surround during the drying process.
Any help is really appreciated. Thank you in advance!
Worked out a DIY cone to surround clamping system hahaha. It's the worst looking thing ever, but I have pressure up on the cone and even weight pressing down around the surround. If this doesn't work, I'll have to really find out what others have used to clamp the inner edge of the surround down to ththe cone. Also working on fixing a type r voice coil....
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
385
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
311
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
695
11
557
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
MrSlaybury
MrSlaybury
New Hampshire USA
MrSlaybury
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
