Need a new Amp for my 18 asap!
  • 3
Why So Cereal?
Invisible Cereal
so as of now i have a cadence dakota...2400 max, (supposedly 1200 rms) amp on my fi q 18 (dual 2 ohm)... basically it does nothing for the sub at all. and the amp will get hot as eff and then shut off. to even get the amp to do anything i have to crank the gain near all the way up and the bass boosts up..otherwise..u can barely tell the sub is even back there. so now the shop i go to says i can trade it for a hifonics brutus 1200 or an autotek 4000 maxx (both maxxsonics)...he also sells other cadence, powerbass and such...so my question is...should i switch it for the brutus or the autotek? or is 1200 watts simply not enough for this sub? i have adequate power... 800 amp batcap right next to the amp. sooooo HELP PlEASE!
11
662
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
964
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Why So Cereal?
Invisible Cereal
Why So Cereal?
Drowning in milk
Why So Cereal?
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
