need a powerful good amp
  • 4
hey Guys, I am running 2 zv4 12s and I always seem to get amps that will not run them because I am just too cheap, but now I'm ready to spend the money for a good amp I need around 4-5k Rms and be able to be wired down to .5 ohms all within staying in the $800 range, any possible amps you guys could think of????
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
213
Thanks for your input! I did some research and wanted to share what I found for anyone else in a similar situation. It turns out that the Honda...
179
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
510
Carsonb99
Carsonb99
Greenville Mississippi
05_ZX636
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
