Need a radar/laser detector
  • 3
Absolutely the Valentine one. It is pricey (though the same as it's competitor the passport 8500) but mine has EASILY paid for it'self 10 times over. It's range is incredible, and it has never falsed on the open highway for me in the 7 months I have owned it. If it chirps, there is a cop.check :http://www.speedzones.com/ for a bunch of tests on everything you could imagine.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
155
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
116
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
462
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
354
Alpine2005
CARROZZERIA
Alpine2005
CA
Dj-torn
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
