Need advise. please.
Mix matching subs is a recipe for disaster or at least disappointment.
^^^^^this^^^^^. Different specs and ts parameters will usually cause cancellation issues sell one of the subs. Buy a mating to the other. Then strap the amps on both subs
How would I strap the amps? The amps are mono Amps with two speaker hook up. Will that mess anything up?
I don't believe those Orion amps strap. Just pick ONE TYPE of sub and buy or trade into enough to do what you want.
Try to dig up a copy of the manual to see if your amps can be strapped.
372
You can just change the surround if the cone is not broken. This picture shows all the measurements you must make.
486
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
409
noaar_s8051
noaar_s8051
Oklahoma City, Ok
noaar_s8051
    Jun 1, 2024
    May 31, 2024
