Need advise. please.
  • 3
Mix matching subs is a recipe for disaster or at least disappointment.
^^^^^this^^^^^. Different specs and ts parameters will usually cause cancellation issues sell one of the subs. Buy a mating to the other. Then strap the amps on both subs
How would I strap the amps? The amps are mono Amps with two speaker hook up. Will that mess anything up?
I don't believe those Orion amps strap. Just pick ONE TYPE of sub and buy or trade into enough to do what you want.
Try to dig up a copy of the manual to see if your amps can be strapped.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
161
You can just change the surround if the cone is not broken. This picture shows all the measurements you must make.
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
118
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
464
noaar_s8051
noaar_s8051
Oklahoma City, Ok
noaar_s8051
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
