Need Amp Help
  • 2
Check your ground first, if you do not have a good ground the amplifier can be looking for ground along the RCA path. If that doesn't do it, try changing to a different speaker, to see if scratchy-ness continues. If it does continue and you can eliminate the speaker, try changing RCA input by swapping to a different output on your radio. If it STILL continues it would be something inside the amp itself.
11
954
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
w.hardwick
w.hardwick
Kentucky
Innovative:Cory
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
