Need enclosure advice. JLw1 to JLw3
  • 4
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
137
192
Duncman09
Duncman09
Austin, Texas
audiobaun
    May 19, 2024
    May 19, 2024
