Need expert advice
  • 4
dcmaidens
I've narrowed in on four double din units I am interested in. Can you please give me advice and opinions on which one is the best choice? I want to build a budget high sound quality system. I would like to start with a great double din head unit, but I don't need an AV unit.
The units are:
Sony WX-GT90BT
Clarion CX501
Kenwood DPX500BT
JVC KW-R900BT
Thanks for the help.
Any of those units should sound good in a controlled environment. The Sony unit has the most powerful EQ, but it's still lacking in tuning features.
That's what I was thinking too. I would prefer a higher voltage though. I don't know if the Clarion has a 24 bit DAC, and I am leery about JVC. The Kenwood seems nice too.
I am shocked that not a single manufacturer, besides JVC, has a feature packed double din unit - that isn't an a/v unit. I would think with the added real-estate and not dealing with video, touch-screen, even eliminating the CD component, would allow the manufacturers an excellent opportunity to stuff in great components. I want a double din so I don't have that stupid useless pocket underneath.
Is there a way to increase voltage from a head-unit? If so, and I go with the Sony, what could I add-on to make that deck superb?
For any of these units you could add on a full-featured DSP. I used the Clarion CX501 with a JBL MS-8. As a basic CD transport it sounds excellent. The addition of aux, USB, and Bluetooth are very useful and the quality is good with those features as well.
I don't find it necessary for pre-out voltage to be any higher than 4V. You can bump it higher with a line driver, but I don't recommend it as it's not necessary.
JVC has been doing very well recently with their head units. I keep hearing great things about them. The same goes for Kenwood and Sony.
That JVC is a step up from what I have and I'm satisfied with mine. I added external EQ though cuz I only have 3 bands on the HU. I like the multi color display and front USB and AUX connectors. They also have a 24 bit DAC but I think most decks do nowadays.
I agree with ya though, there should be high end SQ double DINs without the AV stuff. So many OEM dashes use DDIN.
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
137
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
192
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
144
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
500
dcmaidens
dcmaidens
Winnipeg, MB
dcmaidens
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
