Need h3lp with Atoto F7 XE wiring for steering control on Silverado 2012
  • 1
Hi folks, I am I stalling subject system on my 2022 Silverado. I removed my aftermarket Hizpo system which I had connected with a CAN BUS XRC controller. (See picture).
43988
I can't figure which wire to connect to the Steering Wheel Key#(+) and Steering Wheel Key(+) wires on the units wire harnest?
43989
43990
43991
Help please
View attachment 43989 View attachment 43990 View attachment 43991
Help please
Update: I emailed Atoto support. They are asking me which wire in this Simple Soft CAN BUS controls the steering buttons? If I knew that, I wouldn't be asking anyone else for help...?
Perhaps someone out there has a wiring map for this Simple Soft GM-SS-03 CAN BUS interface?
That would greatly help me if you did. Thank you.
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
137
192
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
144
501
landriaultp
landriaultp
Gatineau, Québec, Canada
landriaultp
audiobaun
    May 19, 2024
    May 19, 2024
