NEED HELP! 2006 GMC sierra extended cab
  • 2
TyWilliams
Hey guys I need some help. I'm fairly new to Car Audio but am already becoming a enthusiast. I want to run, preferably, a pair of Fi BL 10's ported somewhere in the range of 32-32 Hz. As you know there is not much room under the seat of a extended cab truck, but I have seen it done. This is all I have found as far as a ported 10 design goes, but its for one: View attachment 26538913
I want two. The minimum space needed is .7 through 1.5 cubes. I have seen sealed boxes built as big as 1.12 cubes(SubThump Ultra deep MAXX) so I should be able to get at LEAST .7 after displacement. so now I need help with the design. I was thinking subs up port out, Anybody smarter than me know how to make this work?
Seat lift woukd clear up a bunch of space. Use fiberglass for top and bottom of box to save space.
I think it was 'ado' who built a nice ported box for single 12 under seat. T4y to find his build thread and that may help
Check out Crutchfield to determine the iData, PAC, Maestro Harness you will need to retain the infotainment/steering wheel functions, then we can...
11
653
719
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
956
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
TyWilliams
TyWilliams
United States
TyWilliams
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
