need help!!!! amp repair mtx thunder 81000d
  • 1
timbassett
Ok so I bought an amp that's broken off of cl and it needs repair the amp goes straight into protection mode and there are some obvious issues and I tried to patch it up but dosent seem to want to leave protection mode all fets are fine but 2 capacitors on the board are swollen but still charge up c487 and c489 the rest of the larger capacities farther down seem fine but are a bit swollen too the negative trace on the bottom of the board however literly split in 2 from over heating i tried to just jump the trace and see if it would start back up but nothing happend and i tried removeing the caps but before I replace them I wanted to know if anyone would know what's the actual issue power supply seems fine getting 100+ volts out of the 2 prong d444-d447 any help I'm clueless View attachment 26533344View attachment 26533343View attachment 26533342View attachment 26533344View attachment 26533343View attachment 26533342View attachment 26533344View attachment 26533343View attachment 26533342
11
666
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
969
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
timbassett
timbassett
newington ct
timbassett
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
