Need help choosing amp for HAT Imagines
  • 4
slvrdrgn123
Need help choosing an amp for the HAT Imagines. I will be running them active off the amp itself so it will need built in x-overs. Been looking into these, don't want to spend too much on the amp right now. Budget is $150-$175. Which one would be best? Thanks.
Amazon.com: Autotek M2000.4 4 Channel 2000 Watt Maxx Amplifier: Electronics
Amazon.com: Soundstream RUB4.600 100 x 4 4-Channel Amplifier (Midnight Blue): Car Electronics
http://www.amazon.com/Hifonics-ZXi150-4-Zeus-Stereo-OHMS/dp/B0036B8UTS
http://www.sonicelectronix.com/item_38338_Precision-Power-P900.4.html
Thanks for the input guys. I just found this one for about $230, it a PPI Phantom 900.4. Is it better than the rubicon? Linked to it in first post.
They all ****. Why? You're not going to get a quality x-over, EQ, or any processing with a
For your application, active, you're going to need to spend more than $175 if you want the best sound. If you're on a budget, use passives. Running speakers off a cheap amp's crossover will sound bad no matter what brand speakers you're using. So, those amps you've been looking over will all be poor choices. In addition, cheap amps use really bad sounding x-overs anyway and you do not want to rely on those.
Here is my thought, theory. Those speakers are 80w rms. Half of that is 40w rms. Add the 40 to the 80 and you get 120w. Get an amp that is 120w...
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
I have 2 Sundown SA10v2 (1000w version) and just replaced my RF R1200 with a T-1500.1bd and OMG! I was considering Ampere Audio, JP23, Sundown...
5
well, thats kind of an open ended question....., you can do 2500rms@1ohm, or you can do a pair of 1k-1200rms@2ohms. just have to know the amp...
5
slvrdrgn123
slvrdrgn123
California
slvrdrgn123
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
