Please help in choosing my next amp for jl pro wedge pre built 13.5" box
ATN2DETAILING
BURBANK
Hello everyone,
I wanted some suggestions on a regulated power supply amp to run a single pre built JL prowedge 13.5" subwoofer... The enclosure is a final 3ohm so till now I've only came up with the JL 1000.1 . If you have any suggestions or alternatives please advise. Thank you in advance and have a great day!
I was looking at the hifonics 2400 but someone suggested going with a "regulated" power supple like the JL's because of the 3 ohm total finish impedance...
no using Credit cards so that rules out most private party sales...
---------- Post added at 01:11 PM ---------- Previous post was at 01:11 PM ----------
unless something out of the ordinary comes along then I will buy used/cash...
its a great amp you will be very happy. i personally like the xenon a lil better but both amps are awsome and id get them over the jl any day
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
955
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
ATN2DETAILING
ATN2DETAILING
BURBANK
mclerico83
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
