need help deciding which direction to go
  • 2
DaStonedSmurf
Ohio
Car: 2001 Hyundai Accent GL with Alpine 7558 head and CD Shuttle
Used as daily driver and family car.
Left over equipment from previous installs:
Boston Rally componet set
1~ 12" kicker 4ohm sub
1~ 10" JL Audio 10w6
Xtant 404m 50wRMSx4 each pair of channels
can be bridged for 200wRMSx1 @ 4ohms
MMATS D200hc about 500wx1 @4ohms &
1200wRMSx1 @1ohm
Problems: no space or alternator power to run both
amps
Question: 1) do I run the highs and a sub(under powered) with the Xtant or give a sub plenty of power from the MMATS and just have whatever highs the head unit can give.
2) if I go with the Xtant which sub would run better on that amp?
Fred
dastonedsmurf@yahoo.com
use the xtant- use the front channel to
power your boston set and bridge the rear channel
to the kicker 12 use the passive crossover that
came with the boston set to protect the mid and
tweeter you will also need to buy a sw 100
passive crossover for the kicker 12 you can
buy it at any car audio shop that sell kicker
They are good at the boom. Hard pounding lowend but lack at the upper notes. If you have a strong midbass setup they will blend fine. Buuut.. for...
13
673
958
922
DaStonedSmurf
DaStonedSmurf
Ohio
DaStonedSmurf
