why do my speakers cut off?
  • Thread starter <motoxrthumper>
  • Start date
  • Replies 3
  • Views 2K
  • 2
<motoxrthumper>
Guest
I had the stock system in my 95 nissan altima for about 2 years and it played fine except for the fact that the front tweeters and 5x7s in the door just cut off and stopped playing every once in a while. The rear 6x9s would just keep on playing by themselves for a few minutes then the fronts would come back on. I got tired of this so i got all polk audio speakers and an alpine head unit and THE FRONT SPEAKERS STILL CUT OFF!!!! what is the deal?
hey man fist you need to find out if you got a bose system inthrere or not if so you probably have bad amplifiers on the speakers and if not do you still have the factory radio if so you can go by mb quarts and they still will cut off
hey man first you need to find out if you got a bose system in there or not if so you probably have bad amplifiers on the speakers and if not do you still have the factory radio if so you can go by mb quarts and they still will cut off
motoxrthumper- so you upgraded to an alpine
head unit and the front speakers still cut off
did you wire the tweeter to the polk like you
did with the old set if you did try removing
the tweeter from the polk set and see if it shuts
down
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
101
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
7
202
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
331
Guest
billetz23
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
