Need Help? Let Me know
Today me and me new employee worked on a 2011 Nissan 370z. IT was COLD and it SNOWED but he stuck through it and learned a lot.
Already hard at work! We both took a door and he mirrored what I did to the other one.
Doors removed and starting to run new wiring.
Learning to work in tight spots!
Soldering is KEY!!
Rest!
SNOW!
Tweeters installed
Everything mounted and tested. Forgot pics of the head unit and speakers
I am currently working on a 3 day ISF full audio build.
Products:
JBL MS8
Hertz 6.5 Coaxial rears
Pioneer Stage 4 components running active
2 Audison LRx amps and a alpine PDX M12
2 Alpine Type R's
2nd Battery
I will break down the wiring diagram as best I can for future installers.
Removing door panels
Stock speakers vs aftermarket
Solder and heat shrink connections
Rubber tape to wrap them all nice
Rear seats out
Battery ground upgrade
Factory mid location now home to tweeter. Not pretty but very strong. Gorilla epoxy
Sub wiring
Ok got the owner to send me the pics, have some more to come so please be patient!!!
Trimmed the battery terminal cover to allow for the power wire to come out.
Work in progress pics of the power wire wake up wire and so on.
Organizing all the wires, zip tied every 6 inches or so. The two grommets towards the top of the rear seats provide great locations to run wires. NOTE make sure to cover them with some kind ot rubber rap and or shielding.
Labeled all the outputs for the amps as for quick reference.
Battery grounded, made sure there was no resistance for this ground.
Amps installed on new rack
Owner wanted easy access to his bass knob and radar
Wiring up all the power wires!!
Here are some finished pictures. Will get more when he comes for tuning. I will also check out if adding the sub to the inputs for summing adds anything.
Fuse block was placed on top of the fuse box for a few reasons.
Quick removal is you need to get to fuses.
Held in place with no drilling any holes.
Perfect location
Also the ground wire was upgraded as well, using the stock grounding location only paint was removed and stock bolt.
Subs installed
Last year I worked on a members z and put the fallowing in:
Kenwood 9980 head unit
JBL MS8
Hertz Mile speakers
Hertz sub
Audison 5.1K amp
The owner wanted even more sound so I came back this week to do "stage 2"
Added:
Focal FPS 21160 amp
Hertz Hi-Energy coaxial speakers"rears"
Kinetick KHC140 battery
Kicker 0 gauge battery
Stinger fans
Custom speaker pods
Made the rings
Pulled the carpet off the panels
Started finding the right angle to mout the rings.
Starting to epoxy the supports
So far
11
478
590
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
860
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
bigaudiofanatic
Dynamic Mobile Audio
bigaudiofanatic
Dover DE
FreddyNJ
Latest topics
