need help on port design. Will pay if needed need asap
  • 1
on1wheel01
Bang A Lang
Hey guys about to build a box for a 240sx. Doing a wall like build. Not sure how to design port as dont usually do the bottom ports, so if someone could design it for me I would appreciate it and could throw you a few bucks for it. Width I want is 32" wide. 18" deep can be slightly deeper if needed, front of box top(closest) to front seats is 25 1/2 high, back of box(closest to hatch ) 21 1/2 high. It's for a sundown nightshade 18" v3 prototype he bought from sundown. I need 4 cubes after port and sub displacement tuned to 32 hz with a double baffle also. He is wanting the port at the bottom of the box under the sub if possible with both being in the middle of the box. Both firing forward. If thats not possible, I want the sub behind the passenger seat with port at bottom behind the drivers seat. Let me know what yo u can do. pm or hell text for fastest response but I will be checking this regularly. 704 658 5764
__________________
None so far, there was a factory 8 inch subwoofer that I took out for a pass through, I'm definitely going to have to get some sound deadening...
10
11
648
715
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
955
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
on1wheel01
Bang A Lang
on1wheel01
Mooresville nc
on1wheel01
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
