Need help specing an amp
  • 1
SR20
Hell
So ive got 2 12" Rockrord P3s (ref: Rockford Fosgate® - P3D412)
Specs: (one speaker)
Impedance: 4-Ohm x 2
Power Handling: 500 Watts RMS, 1000 Watts Max
So im trying to spec out 1-2 amps for this setup, Ive got 0 gauge to the trunk so power is not an issue. (also have a kinetik battery for some power support).
1 amp would be nice but im not looking to spend a arm, leg and first born so i was initially looking at 2 amps. However im not really sure what I should be looking for in amps.
So what amps should I be looking at?
how do I figure out how much I need for these speakers. (im confused due to the dual voice coil)
Thanks
Thank you, I did check the ground and and fuse holder wires and everthing is fine. All I did was swap amps and the previous Alpine pdx sounded...
64
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
719
11
987
953
SR20
SR20
Hell
SR20
