Need Help Tuning 2 Amps In Miami Dade/Broward/West Palm Area? Need An Oscilloscope.
  • 2
Everything is brand new, installed, and in working condition. I just need my mids & high amp, and sub amp tuned. Sometimes, the music, sounds sloppy, either too much bass in the interior speakers, or sloppy bass from the subs, which I'm assuming is distortion.. All cables are correctly installed and grounded properly. Sealed box.
AMPS
Hifonics Brutus BRZ1700.1D
Pioneer GM-6400F
AMPS
Pioneer GM-6400F
pm me your phone number and name and tommorow i can give you a call if you would like to come up i will be happy to spend a bit of time tuning it , should take 10-20 minutes at most
$10
Did you say you dropped it off at the autoshop? Well that's the problem. Not all all mechanics are made alike. Even if they are ASE certified...
5
Turn the subwoofer output to max. Turn the gain down on the amp to where you're comfortable the the amp isn't clipping. Play a 0db sine wave at...
17
Thank you it sounds way better then it was And I fixed why it was cutting off it was because of bad power because the full range amp was losing...
4
11
522
633
gyzo33
gyzo33
Miami Beach, Florida, United States
gyzo33
DEW123
    May 7, 2024
DEW123
    May 7, 2024
Latest topics
