Need help tuning a bandpass!!
  • 3
Elyjah
CarAudio.com Newbie
I recently started my box build for 2 15" skar subwoofers. As of right now it is a simple 6 peice box with a single circle cut in the front to fit one of the 2 subs in. The inside diminsions of the box are 24x28x15.5 inches making it 6 cubic feet without anything inside the box. What I have brainstormed on doing is putting a double baffled wall slightly off centered in the middle to mount my second sub putting it in an isobaric postion... I will then port the 2nd chamber to 30hz or plan to. This is where I've hit a wall and need help. My subs recommended airspace for a sealed enclosure is 1.79 cu^3. A ported enclosure recommends 2.3cu^3. I need to know if an extra bit of cubic space will render my subs at risk and also how to tune a port to 30 Hertz when it is in an isobaric config. I think that anybody that has read this far may be able to help me so if anybody would be willing to lend a hand that knows how to calculate ports for bandpass enclosures contact my email at elyjahstravis@gmail.com
Thanks for any suggestions!
2.3 cubes ported for a 15? Which one is it? I usually see quite a bit larger recommendations for 15s
Did you say you dropped it off at the autoshop? Well that's the problem. Not all all mechanics are made alike. Even if they are ASE certified...
5
Turn the subwoofer output to max. Turn the gain down on the amp to where you're comfortable the the amp isn't clipping. Play a 0db sine wave at...
17
Thank you it sounds way better then it was And I fixed why it was cutting off it was because of bad power because the full range amp was losing...
4
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
442
Elyjah
CarAudio.com Newbie
Elyjah
DirtyDuzit
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
