Need Help Tuning
  • 2
Well What sub(s) do u have, and What size box, Port ect. Anyways, u Make the port shorter, it will tune it higher, make it longer, tune it lower. But let us know what u have, and we can help u
Did you say you dropped it off at the autoshop? Well that's the problem. Not all all mechanics are made alike. Even if they are ASE certified...
5
Turn the subwoofer output to max. Turn the gain down on the amp to where you're comfortable the the amp isn't clipping. Play a 0db sine wave at...
17
Thank you it sounds way better then it was And I fixed why it was cutting off it was because of bad power because the full range amp was losing...
4
11
474
589
vettelovr1124
Livin' Life
vettelovr1124
Memphis Area/ B'Burg
vettelovr1124
Latest topics
