need help wiring 3.5mm jack into old stereo.
  • 3
so today i started a new project to wire in a headphone cable into my stereo so i can connect my ipod.my car is an 83 toyota cressida.
Since it has no aux ports or anything like that my plan is to just wire in the 3.5 jack into the audio source and add a switch onto the source to turn off the radio audio so the ipod audio will play.
Problem is.....i can't find where the source is..
im looking in the volume control knob area right now and am having no luck.
any help with this or with a better/easier way would be appriciated:)
thanks- fly
theres ur problem.
thanks- fly
theres ur problem.
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Is that 1000w max? Don't expect to be able to bridge a 1000w amp at 2 ohms and get 500w x 2ch. I'm pretty sure you can't with that amp, for...
xlflylx
xlflylx
asdfghjkl, ca
06goat
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
