Need help with amp has power, no output
  • 1
Macey54
So I am stumped. My system has worked great for years. All of a sudden I started the truck one day and my subs weren't playing. I have a 12" pioneer running off my cpt1-2000.
Anyways, power and ground check out. Remote wire checks out. Sub is functioning. And I have signal from my rcas. I've tried playing with Hu and amp settings. Could this be anything other than a cooked amp? This just seems unlikely because all I've played in the last year is country....
Any help would be greatly appreciated!
11
974
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Macey54
Macey54
Salisbury, ma
Macey54
Decebal
    Jun 10, 2024
