Need Help With 'Factory Look' Build
  • 3
MuggaMan
CarAudio.com Newbie
I want a new audio setup to be as hidden and factory looking as possible. The shelf behind my rear seats have two factory freeair 8" 'subs', so to retain boot space, and factory look Im thinking of Dynamatting the shelf and chucking two new subs in there (I know this is nowhere as good as a box).
I'm in Australia (brand selection is very limited) but I'm considering the 5 chan. Kicker KXA800.5 Amp to power new component Kicker door speakers and the Subs.
1) Would 2x Kicker 8" CWCS84 4ohm, SVC, 200W RMS subs work efficiently on the above AMP's sub channel in parallel or am I misunderstanding specs?
2) I'm also open to alternate brands etc. for the whole system. The Australian website im going off is https://www.ryda.com.au (all prices are in Aussie dollars). I have an android head unit already and my 4 door speakers are all 6.5". Front of the sedan has factory tweeter locations for splits. My total budget for Amp, 4 Door Speakers, Subs, Wiring is AU$1500.
Any help would be much appreciated 😊
Your idea isnt a bad one, but the rear deck will need some bracing, so look into remaking the entire cover for that and incorporating the subs. Can you buy off eBay? You would be able to find that amp for $250USD leaving you a bit of room for the subs and mids/highs.
I am considering upgrading the sound system in my 2013 Ford F150. I have identified three potential head units: the Sony XAV-9500ES, the Pioneer...
11
652
717
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
956
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
MuggaMan
CarAudio.com Newbie
MuggaMan
Sydney, Oz
MattinMO
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
