need help with system
  • 4
sxkicker89
ok my system is making my lights dim.when i drive they r flickerin when the bass hits.wat can i do to help it.here is my car and system
2003 mustang
hu-alpine 9856
front-kicker 6x8
rear-none
subs-2 12 l7
front amp-sx 400.2-8 awg kit
sub amp-sx 1250.1-4 awg kit
well first u should change your batteries and upgrade your altinator and fuses and there u go problem solved...//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
First step is not to blow a lot on batteries or alternators. Check out the threads on "the big 3" this will make your electrical system more efficient, then if you still have dimming upgrade alternator and batt.
Unless you know nothing about your vehicle other than where the battery is //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Humm, good point. Ok, if you can follow directions you can do the big 3. All of the steps are layed out for you, it's very simple (maybe not easy, but simple).
Well I’m on the gp website and I’m looking and I found the one I’m going to get but I’m unsure if the length I should get. Standard is 4ft should...
10
662
sxkicker89
sxkicker89
delaware,dover
gijoe
    May 18, 2024
    May 16, 2024
