Need help with wiring diagram for a 98 Volvo s70
  • 3
Rage00
can anyone help me with a wiring diagram for a 98 Volvo s70. I am need of one. I am trying to figure out which is the ignition wire. I'm trying to wire in a power source for my wifes xm unit that can stay hiden out of the way and she will have access to her outlet to charge her phone when needed.
thanks for the help
why dont you tap into the wire for the ignition at the fuse box it should be labeled ign fuse and will work just fine just tee into the wire behind fuse panel
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Is that 1000w max? Don't expect to be able to bridge a 1000w amp at 2 ohms and get 500w x 2ch. I'm pretty sure you can't with that amp, for...
Rage00
Rage00
Grand Rapids, MI
Rage00
Decebal
    Jun 10, 2024
