need help with wiring some LED
  • 4
run them to your trunk light, so when you pop the trunk the LED for the box comes on, or you can run it to the remote to amp and it will come on when the amp comes on
If you power them directly from the amp power wire, the LED's will always be on. Use a relay activated by the remote turn on lead to turn them on. You can use the amp ground and + for the supply.
imma just run a separate 16 gauge wire from my battery since imma place my switch next to the center console. i rather go this route then using relays. It sounds more of a hassle using relays than running a separate power wire. anybody know the fuse rating i should put on the 16 gauge? and the specs for my switch, 50mA 500mA, 1A, etc?
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Is that 1000w max? Don't expect to be able to bridge a 1000w amp at 2 ohms and get 500w x 2ch. I'm pretty sure you can't with that amp, for...
thaster
thaster
pennsylvania
thaster
    Jun 1, 2024
    May 31, 2024
