COMPLETED Need highs and mids for 2 Sundown ZV4 15s
  • 1
cutty cochise
20
Delaware
What's up yall! Need 2) 6.5's and 2) 8s and 6) tweeters that's going to keep up with these 15s! Prefer a good neo but anything but "prv"!!! I'm all about quality crisp sounds!! I'm used to Hertz and Beyma! New level of thump going into this project! It's going inside a 1973 convertible! Thanks in advance!!
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
168
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
122
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
468
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
361
cutty cochise
cutty cochise
Delaware
cutty cochise
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
