Need inclosure designs for a single 12 ( fast please )
  • 3
Tek18
KY
Looking for a nice enclosure, its for a buddies ford focus and it is a obsidian audio 12" running around 800 watts, maybe a T line? he doesn't want a bandpass.
Thanks
also quick question..
i can't remember the math equation... 1ohm at 1000watts is 31.5V output? how did i get that number.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
155
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
116
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
462
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
354
Tek18
Tek18
KY
pro-rabbit
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
