Need low profile speaker grills for 6.5"s...
  • 2
MrOneEyedBoh
20
Md,USA
I installed some ID CTX 6.5 components and I needed to use the speaker grill because they were hitting the back of the door skin/stock grill. But the speaker grills that came with the IDs are super thick and bulging the doors out. Is there a low profile speaker grill I can use? Can I use ANY 6.5" speaker grill? What about the speaker rubbing on the grill? Thanks!
Can I get some lexan rings cut out and just follow the outside diameter of the speaker? That would space it off of the door skin... right? How thick should I make the lexan?
Like this:
You can use a 2 channel one and just use RCA Y cables to go from 2 to 4 outputs Do yourself a favor and get one with a line driver built into it...
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
171
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
126
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
470
MrOneEyedBoh
MrOneEyedBoh
Md,USA
trumpet
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
