need more powerful speakers
cmctburn
I have a pair of 15" pioneer ts-w384-dvc's I need to know what other speakers can I use for the box I have for those speakers I had it custom built for my truck. I need better speakers
What is the volume of the box? You can do a lot having that info.. Many subs use similar box dimensions and so may be swapped out.. but remember that when a speaker calls for say 2.5 cubic feet that you must stay withing %10 of that volume or you are liable to hurt the sub, or it will sound like crap.
Mike
if the box is between .88-1.5 per chamber i say u get some performance tekniques. they r a new brand but the slam hard a hell. my freind has some and i'm getting some. in his ford explored they were hitting really hard.
what kind of amp do you have? that can make alot of difference also. do you have the power to push those bad boys? find a friend who has a more powerful amp than yours and try it out before you get new subs. if it still sounds like hell go 4 the new subs. just b careful what kind of amp because total watts don't always mean anything.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
160
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
117
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
464
cmctburn
cmctburn
Memphis, TN
audioman
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
