Need new amp
  • 4
TruLegend
8
US
I have 2 mofo 152x DVC i feel like i want to run at 2 ohms, but i dont know what to get for an amp. I want to rms about 3000 watts Budget is low, less than $400. My ideas are a taramps HD3000 2ohm, 2 audiopipe apcl 1500 strapped to 2 ohm, or other 1500 watt 1 ohm amps strapped to 2. Possible a soundstream t1.6000 dl at .5 ohm. I think i would prefer 2 ohm though, suggestions?
Sent from my SAMSUNG-SM-J120AZ using Tapatalk
Why do you want to run at 2 ohm? Is it because if you wire it down it would be at .5 ohm? If so you won't have a problem unless your using anything else but a class d amp or bad electric to to even power 3000w but that still will be and issue at 2ohm because your electric is insufficient. When your wired down to .5 ohm that is nominal. With box rise while playing you will be closer to 1 ohm or higher. Also I have a Orion zo12000 brand new 3000w at 1ohm and I can do $325 shipped
Its the 2 ohm dvc i feel like i want to run 2 ohm rather than wire down to .5 because i can get same wattage at 2 ohm for possible better quality i guess, i dont really know. Im kinda bew to everything with the subs, and i dont have anything to compare sound difference from 2 ohm or .5 ohm
There will be no difference in quality especially since it will be powering a sub vs mids and highs. But the only benefits of wiring 1 ohm amp at 2 ohm is the damping factor increases. And I can tell you I can't here not one bit of difference. Don't believe anything you hear. I always listen to other suggestions and ask or make my own assumptions from my own testing
11
957
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
TruLegend
TruLegend
US
Rambo
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
