Need new Subs
  • 4
ryanwilcox
I Just blew my Subs and amp. (Subs are old and going bad and caused the amp to blew)
Looking to use the same sub box cause its custom fit for under my seat.
Looking for a 10" sub with a mounting depth less then 4 3/8"
I had 225 watts and want to louder. (300 up probably)
I really like the compRT's but i cant find an amp that can do 800watts at 2ohms
would it be a probably if i used a 600 watt amps for two speakers that each are rated at 400 watts rms?
Do you have any suggestes for sub amp combos?
https://www.bestbuy.com/site/kicker-comprt-10-dual-voice-coil-2-ohms-subwoofer-black/5190204.p?skuId=5190204
https://www.bestbuy.com/site/kicker-cx-series-cxa6001-1200w-class-d-mono-amplifier-with-adjustable-kickeq-bass-boost-black/4781400.p?skuId=4781400
Will 1255W be to much power?
Depends on your amp and woofers and install. Most amp companies inflate their ratings and lie. U need to make sure the amp your buying is from a good company that will do rated power. Then u need to set your gain up to match your HU preout voltage to ensure a clean signal.. speakers and subwoofers can handle alotnof clean power, all it takes is a clipped /dirty signal and your going to have a bad day.
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
ryanwilcox
ryanwilcox
Toledo, OH
ryanwilcox
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
