Need recommendations/advice for speakers
  • 2
Babbar Khalsa
Hey guys I need your recommendations and advice on a new speaker upgrade I want to do in my 03 tacoma extended cab.I am planning on installing 6.5 component speakers. My budget is $550 for both front and rear speakers. I do plan on adding a sub later on, my headunit choice will most likely be a pioneer single din. What I want is good quality with clean accurate sound and with good mid bass. I do plan on running a 4 channel amp as well, so if you guys have any recommendations for that too please let me know. Thanks!
Thanks for the reply. Just looked up the speakers set. Should sound good for what am doing lol and not bad of a price. What amplifier would you go about using for these speakers to get the best out of them?
I've got a couple that would work really depends on your budget send me a pm and I'll give you some prices if needed or wanted. I'm also a authorized cdt dealer here
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
Are you saying that I should replace the jack on the headunit with a wire instead? Is that fairly simple? I'd imagine you would just need to make...
8
No, the $500 does not include the amp, I'll e-check em out. I appreciate it Do you have any specific recommendations? There is a lot of...
The amp and sub are a bad combination. That sub is dual 2 Ohms. It can be wired to 4 Ohms in series or 1 Ohm in parallel. The amp can only go to 2...
4
I am building a nice system in my Ford Excursion using high end 3 way component speakers in the front doors in custom speaker pods, and using 2...
Babbar Khalsa
Babbar Khalsa
Houston, TX
mylows10
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
