Need Recommendations for an Amp
  • 2
HFrosty
I'm looking to purchase an amp and speakers, but I have no idea which amp to buy. The speakers I'm looking to buy: Polk Audio DB6501 6.5-Inch 2-Way Component System (Pair, Silver): Amazon.ca: Electronics
Ideally, I'd like an amp that's cheap-ish and will get the job done well.
In one review for the speakers that I was reading, someone mentioned that the highs from the tweeters are a bit too high and suggested that you "install a 22uF cap across the tweeter posts at the crossover to tame the high end". Can someone explain that to me? It sounds like something I should look in to.
If I need any extra supplies on top of the amp, links for those would be greatly appreciated since I'm having this installed at a local audio shop and I don't want all those added supply fees from them.
Most likely their install was poor and lacking. EX: poor speaker positioning, lack of proper sound processing (low end 150 dollar and under head unit), and overall tuning.
The tweeter attenuation on the crossover should be more than enough along with a proper EQ and on axis(facing directly at your ears) tweeter positioning While avoiding reflections from the windshield causing a massive spike in the upper frequency range.
If they had it firing up the dash, or off axis near the windshield then yes there will be harsh and overly bright tweets that only an advanced EQ from a dedicated Digital sound processor can tame.
For amps, I'd go with PPI amps if you want budget power. Look for a black ice 800.4, there's one in the classifieds if you dont mind buying used.
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
Are you saying that I should replace the jack on the headunit with a wire instead? Is that fairly simple? I'd imagine you would just need to make...
8
No, the $500 does not include the amp, I'll e-check em out. I appreciate it Do you have any specific recommendations? There is a lot of...
The amp and sub are a bad combination. That sub is dual 2 Ohms. It can be wired to 4 Ohms in series or 1 Ohm in parallel. The amp can only go to 2...
4
I am building a nice system in my Ford Excursion using high end 3 way component speakers in the front doors in custom speaker pods, and using 2...
HFrosty
HFrosty
Alberta
Jeffdachef
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
