need recommendations for upgrade
  • 3
subbd
CarAudio.com Newbie
USA
i currently have an american bass xfl 12 and a taramps 3000, its in a pretty big custom box but i still want it to be louder, it needs to stay in trunk build territory but what do yall suggest i change up, should i get one big 18 or 3 12s, should i get a taramps 5k or even 8k, whats the best route for me to take?
depends on how much louder you want it. id model it up in WinISD and see what you get
id try different box sizes, more subs, different size subs etc
What Model XFL 12? the 1244 or 1222? What is the Taramps lowest ohm rating at ? Is it a 1ohm stable or 2 ohm stable or 4 ohm stable amplifier?
What Vehicle do you have? Have you done the Big 3 or any other Electrical upgrades other than just Plane Stock Alternator and under the hood Normal Lead Battery? What size is tour Supply wiring to the sub amplifier? Are you running a stock HU with an LOC or do you have an aftermarket HU? What size is the enclosure you have now and what is it tuned too? How is the box laid out and subwoofer to port location, and set inside the trunk space?
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
Are you saying that I should replace the jack on the headunit with a wire instead? Is that fairly simple? I'd imagine you would just need to make...
8
No, the $500 does not include the amp, I'll e-check em out. I appreciate it Do you have any specific recommendations? There is a lot of...
The amp and sub are a bad combination. That sub is dual 2 Ohms. It can be wired to 4 Ohms in series or 1 Ohm in parallel. The amp can only go to 2...
4
I am building a nice system in my Ford Excursion using high end 3 way component speakers in the front doors in custom speaker pods, and using 2...
subbd
CarAudio.com Newbie
subbd
USA
audiobaun
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
