need recommendations on truck/audio security
  • 1
big scott
blazin low, and loud
3,611
edgewood, md
hi guys,
truck in avatar...
i have a new viper alarm 3305v two-way.
i added a glass brake /tap sensor.
i have the hood pin installed.
im trying to figure out what would be the best i could add to this ??
was thinking of adding a pin for the back window .
o i also installed a siren inside the back of the truck. going to put another one under the back.
also im going to pull my hood release cable/handle and relocate it so nobody can pop the hood.
and thing els ??
please give me some idea's .
im going to order some security screws/bolts for my audio system. i bolted down my sub box.
i do have another viper alarm ( the one i took out, need to get it fixed ) but was thinking of installing that as a back up. plus that would give me 3 extra channels i could use.
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
Are you saying that I should replace the jack on the headunit with a wire instead? Is that fairly simple? I'd imagine you would just need to make...
8
No, the $500 does not include the amp, I'll e-check em out. I appreciate it Do you have any specific recommendations? There is a lot of...
The amp and sub are a bad combination. That sub is dual 2 Ohms. It can be wired to 4 Ohms in series or 1 Ohm in parallel. The amp can only go to 2...
4
I am building a nice system in my Ford Excursion using high end 3 way component speakers in the front doors in custom speaker pods, and using 2...
big scott
big scott
edgewood, md
big scott
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
